I had two surveys that I published for the public to use for a small village in NM and now when I open the survey it is asking for an ArcGIS Login. They were working for a few months but now the ArcGIS Login Pop-up appears. It was great when it worked but now I am giving a presentation on monday and am unsure what the problem is. Any help would be appreciated. Here are the links to the web survey forms.
https://arcg.is/1Gjvrm
https://arcg.is/5XG5O
We cannot access this item:
b95a7db77b6f412490f6ee120f5640b2
Seeing as the form loads, it's likely either:
You can see what the item is and decide if it should be shared publicly, then re-share it.
On the question of using this survey as a template, yes.
Store your survey in a group, and as an org administrator set that group as the source for new surveys. For more information see Organization survey and settings management—ArcGIS Survey123 | Documentation
Thanks Chris! I will check to see what it is referencing.
I switched the map out and it opened! Some of my State of NM data was no longer public....arghhhhh. There seems to be one other issue I keep having. I have a Single select grid that selects for the type of form I want to fill out Village Council, P&Z, or Water & Wastewater. Below that are three dropdowns that are visible if the single select grid is selected. What keeps happening is the value does not get filled in and I have to reset them and republish. Don't want to go back and have to recreate since I have like 8 forms already within this survey. Any suggestions?
Glad to hear!
If users need to fill out the select question, make it required.
Your rules to show the next questions are not valid. Can't comment on that without the rules you have set. Survey123 form designer shouldn't care about previously submitted values, just what's in the form. Just make sure the values in the question match the values in the rules for the following questions.
Thanks again Christopher! I deleted the Single Select Grid and went with the Single Select and that seemed to work. It doesn't seem to be kicking out the values so so far so good. I had used pages a few years ago on 123 Connect and am wondering if they are pretty usable in web survey. Any recommendations? I also would like to use this web survey as a template. Can this be done with a websurvey or is that only available with Connect. Thanks again for your help! You are a life saver!
