System ArcGIS 9.3python 2.5Hello, I have 100 polygon shapefiles in a folder (file names: geoc0923, geoc7634, and geoc3923).Each of them has a field called CXXXX (string). For example, geoc0923 has the field C0923. I tried to dissolve the 100 polygon shapefiels based on the CXXXX field ("R").The dissolve process went smoothly, but some error appeared when renaming the output shapefile.The error shows gp.rename_management("outputR.shp", fcName)ExecuteError: ERROR 000012: H:/temp/test\geoc0387.shp already existsFailed to execute (Rename).Please kindly advise correction on the code below.thank you#Import standard library modules import arcgisscripting import os #Create the Geoprocessor object gp = arcgisscripting.create(9.3) #Set the workspace. gp.Workspace= "H:/temp/test" #Set the workspace. List all of the feature classes in the dataset outWorkspace= "H:/temp" #----------------------------------------------------------------- #Get a list of the featureclasses in the input folder fcs = gp.ListFeatureClasses() # Loop through every item in the list that was just generated for fc in fcs: # Break out the name, no path or extension, using the describe object. desc = gp.describe(fc) featureName = desc.name # Get a list of the fields in the featureclass fields = gp.listFields(fc, "C*", "String") #Select R #----------------------------------------------------------------- # Loop through every item in the list that was just generated for field in fields: gp.toolbox = "Data Management" gp.addMessage(type(field)) # Select records (C*, i.e. C7658) # Make temporary featureclasses gp.toolbox = "Data Management" query = "\"%s\" = 'R'" % field.Name gp.select_analysis(fc,("outputR.shp"),query) gp.Dissolve_management(fc,("outputR.shp"), field.Name) #get file name fcName, fcExt = os.path.splitext(fc) # replace the strings you want to fcName = fcName.replace("_Dissolve","") fcName = fcName + fcExt gp.rename_management("outputR.shp", fcName) gp.delete("outputR.shp") gp.AddMessage(gp.GetMessages()) print gp.GetMessages()
