Hi ExBers,
I want to apply the data_filter in my URL parameters. I was linked this article to follow. https://doc.arcgis.com/en/experience-builder/latest/build-apps/url-parameters.htm#ESRI_SECTION1_0A01682276CD4E7985CA7E222BD648C1
I have some experience using ArcGIS Assistant and URL parameters in Dashboard, so understand a little, but not a whole lot.
I have three layers I want filtered, and I want these to filter in the web map and all the other widgets which have triggers and actions on them.
I want them filtered at the time of the user enters the Experience Builder. Previously I was querying the layers in Map Viewer and that meant a long ExB set up time anytime we switched out the web map.
How do I know which data source is 1, 2 and 3? Do I figure that out by looking in Experience Builder's data source properties of the map or should I have a look in ArcGIS Assistant?
This is what I've tried using our Test site and with the appid removed for privacy purposes.
https://experience.arcgis.com/experience/<appid>/?data_filter=ds1:OperationName%3D%27TestD%27,ds2:OperationName%3D%27TestD%27,ds3:OperationName%3D%27TestD%27
This is the query I want to apply to all of them- OperationName=Test or should it be OperationName='Test'?
Hopefully you can point me in the right direction.
