in version 4.24, print widget not printing with Tile layer as basemap, shows error, it prints without tile layer, any solution to print with tile layer?
Hi @mmkmmkv, thanks for posting your question here. The current version is 4.28, so this issue may have been fixed at a more recent release. If you can share a reproducible test app that shows the error, we could take a look. I'd also recommend looking at our known print limitations for guidance:https://developers.arcgis.com/javascript/latest/api-reference/esri-rest-print.html
@Noah-Sager this is layerType":"ArcGISTiledMapServiceLayer" which is added as basemap which is published as tiled layer which is a image, also this is not working in 4.28, for this any permission needed for print as pdf, png, etc?
Also, when added as MapImageLayer, it shows error as, message: "Unable to load image: https://.../MapServer/export"name: "mapimagelayer:image-fetch-error"
Is any export permission required?
I just checked Image Tile layer its spatial reference is 3857 but published tile layer has spatial reference of 4326, does it make a difference?
In export url, i tried below url:
https://.../MapServer/export?bbox=(SPECIFY_BBOX_HERE_OF_3857)&bboxSR=3857&layers=&layerDefs=&size=&imageSR=4326&historicMoment=&format=gif&transparent=false&dpi=&time=&timeRelation=esriTimeRelationOverlaps&layerTimeOptions=&dynamicLayers=&gdbVersion=&mapScale=&rotation=&datumTransformations=&layerParameterValues=&mapRangeValues=&layerRangeValues=&clipping=&spatialFilter=&f=html
how & where to specify imageSR in print service for export? or bboxSR? if required
Above code prints empty pdf which has basemap tile layer, any reason or any suggestions?
