Hi
We are using the Exp Builder trace widget to perform UN Tracing, Although in ArcGIS online it shows we can buffer the output results of the tracing is there a way we can do similar thing in ArcGIS Enterprise or developer edition widget. I didn't find any info related to this.
Referred this below article
https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/utility-network-trace-widget.htm
The ability to create the buffer results should be available in the next release of ArcGIS Enterprise (11.3).
It's a bit challenging to identify this via the documentation but you can see that it became available at the last release of ArcGIS Online (scroll to the Utility Network Trace widget) https://doc.arcgis.com/en/experience-builder/latest/get-started/whats-new.htm#ESRI_SECTION1_FC4FB9B04D3546978C1B7CA2EA891356
If you look at the last release of ArcGIS Enterprise 11.2 you won't see any updates to the UN Trace widget https://doc.arcgis.com/en/experience-builder/11.2/get-started/whats-new.htm#ESRI_SECTION1_5E2CF93CB8FF4740B8636FDCD88AFB34
Hope that helps
Gelisa
Ok thanks for the update
