Lance- Today I'm on a 10.2.2 machine, and I did the same thing as yesterday. Everything works here so I think it's not an issue.....
Your best bet is to contact Technical Support. They have a standard procedure for downloading data.
Lance- lo and behold... A few years later and I've stumbled upon the problem again. Using v10.0 SP5. I was actually trying to troubleshoot another forum users' problem and this resurfaced.
Here is the scoop:
I have a point feature class with a text-type field to join to a text-type field in another table. I initially set the table up such that it would support a 1:1 relationship and a subsequent join and it worked fine. Here is a screen shot of the points table Joined via the JoinItem field to the datatable (which is shown in the lower portion of the table view window)
Then I altered the table such that it had multiple records, changing the relationship from 1(point) to Many(records in table).
No problem right? I'll just use a summary to get a total for the attribute I want to label the points: so I Summarize on the common join-item in the stand alone table, getting the count of each instance of the join-item and a summary of the values:
But when I try to join the point feature class attribute table with the summary table, I can't:
If you want me to send the data, let me know where to....
Lance- I started this thread 3 years ago in the old forum. I was only 54 then.... In my advancing years, I can not for the life of me remember how I got it to work, but it's a non-issue for me now....
Joe,
Can you post sample data? Are you using 10.0 or 10.0sp5?
Lance Shipman
Geodatabase Product Engineer, File Geodatabase, SQLite, Shapefile
esri, Redlands
same problem... v 10.2.2
Relate works but with the same settings "- No matches found by joining"
(all fields with attribute index)
upd:
For my case i fix it by exporting both tables in same gdb
(reindexing or compact DB wasn't solving problem)
