I've configured my asset package, staged my utility network and now am attempting to apply my asset package. When running the "Apply Asset Package" tool I am getting the following errors.
Apply Asset Package
Parameters
Asset Package M:\MID_Electric\Projects\UtilityNetwork\UN_Test\ElectricUtilityNetworkFoundationV2\Database\Electric_AssetPackage.gdb
Domain Networks to apply Structure;Electric
Input Utility Network M:\MID_Electric\Projects\UtilityNetwork\UN_Test\UN_GeoDatabase.gdb\UN_FD\MID_UtilityNetwork
Load data INCLUDE_DATA
Calculate Spatial Index and Analyze ANALYZE
Output Utility Network
Configurations to apply
Rename using
Post Process NO_POST_PROCESS
Messages
Start Time: Friday, January 26, 2024 9:39:55 AM
ArcGIS Pro 3.0.2.36056
untools 3.0.0
Executing from ArcGIS Pro, 1 map(s), activeMap = True
Parallel processing enabled: 15
Asset Package schema version: 2.9
Staging directory -- M:\MID_Electric\Projects\UtilityNetwork\UN_Test\ElectricUtilityNetworkFoundationV2\Database\AP_Workspace1
A python error occurred.
EXCEPTION
File "C:\Users\ccurtis\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\untools\common\wrappers.py", line 157, in wrapper
f = func(*args, **kwargs)
File "C:\Users\ccurtis\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\untools\gptools\tools.py", line 636, in run
apply.main()
File "C:\Users\ccurtis\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\untools\utils\apply.py", line 809, in main
self.validator.validate_all()
File "C:\Users\ccurtis\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\untools\utils\shared_validation.py", line 175, in validate_all
func()
File "C:\Users\ccurtis\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\untools\utils\shared_validation.py", line 329, in validate_extent
if source.table.extent.within(un_extent, relation="PROPER"):
File "C:\Users\ccurtis\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\untools\describe\base.py", line 201, in extent
return self._create_extent()
File "C:\Users\ccurtis\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\untools\describe\base.py", line 79, in _create_extent
return arcpy.Extent(**kwargs)
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\arcobjects\mixins.py", line 1013, in __init__
self._arc_object = Extent(*gp_fixargs(args), **gp_fixkwargs(kwargs))
RuntimeError
Failed to execute (AssetPackageToUtilityNetwork).
Failed at Friday, January 26, 2024 9:44:57 AM (Elapsed Time: 5 minutes 2 seconds)
My staged utility network looks like this.
Any ideas as to what could be causing the errors?
