I'm working in AGOL with a page that has a table widget and an edit widget. Both are linked to the same standalone table in a feature service.
I use the table widget to select a record, which is then displayed in the edit widget where I can edit the record. I do it like this because I also need to add new records, which I can't do with just the table widget as far as I can tell.
The table has attachments enabled and I can add these in ArcGIS Pro but not in the edit widget in Experience Builder.
Does anybody know if adding attachments to records in a standalone table is possible in Experience Builder?
Hanlie
