Hi UN community!
Several months back, I recall using a geoprocessing tool to set terminal connections for lines in a sewer UN - the tool allowed me to honor the digitized direction and modify the terminal connections for lines in bulk, rather than setting them individually. However, I can't seem to find the tool now. Has it been removed/renamed? Does the tool discussed here: https://community.esri.com/t5/arcgis-utility-network-documents/automatic-assignment-of-from-to-terminal-values-on/ta-p/1307198 accomplish the same thing?
Thanks in advance
You can def use the Attribute Rule you linked, but the tool you are looking for is here:
https://doc.arcgis.com/en/arcgis-solutions/latest/tool-reference/utility-network-package/modify-terminal-connections.htm
Thanks Mike! Are there benefits to using one vs the other?
The tool is more for data migration. The Attribute Rule is used as you edit, so you only have to look at terminals in situations where it cannot figure it out.
