Based on the documentation I found below the current version of Pro only supports up to Revit 2023.
https://pro.arcgis.com/en/pro-app/latest/help/data/revit/supported-bim-geometry.htm
Are there any plans in the upcoming updates to extend support for Revit 2024? If so is there a roadmap/ timeline for when that will be updated?
Thank you!
Hi Bryan,
It is currently planned for the ArcGIS Pro 3.3 release to support Revit 2024. We are currently targeting the next release to be late spring/early summer.
thanks,
Andrew
Hi @BryanOReilly and @MarkusWall1 and others,
I'm happy to share that the Nov. 2024 release of ArcGIS Pro 3.4 includes support for Revit 2020-2025:
https://www.esri.com/arcgis-blog/products/arcgis-pro/announcements/whats-new-for-cad-and-bim-in-the-november-2024-release-of-arcgis-pro/
you can get an idea based on previous timelines
Solved: Revit 2023 support in ArcGIS Pro - Esri Community
but @Andrew--Johnson may have a more definitive answer
This is indeed a problem, as Revit cannot export to anything earlier than 2024 ver by now. So this means that each year there will be half a year of not being able to import new rvt files to AGpro? How about making a patch for this issue? It is a real problem
will Revit 2025 be supported by ArcGIS Pro 3.4?
@TrondRolland1 a possible solution is to export an IFC file from Revit as work around for this half year.
Hi There. This is Kevin with the City of Portland Environmental Services. I was reviewing this thread hoping to resolve my issue with ArcGIS Pro reading my my Revit 2024 BIM models. I am currently using ArcGIS Pro 3.3 and when adding the Revit file I get the following message:
Any suggestions?
Kevin (kevin.ramey@portlandoregon.gov)
hi @MarkusWall1
Can you pass the Revit 2025 fee with Arcgis? I have the same problem.
