Is there a way to change where the ArcGIS for PBI login points? Currently, once you select AGOL or Enterprise, you can't switch it. I often have users who create maps using AGOL option, only to realize later that they meant to use Enterprise. Our current recommendation is to delete the visualization and recreate with the other login type. There has to be a better way to do this.
