I am using this script to change the name/display name of a GUID field in AGOL using a notebook + the name and display name of a relationship. At the end, I get a message that the script was successful, but when I look at the fields in the table in the hosted feature layer, I dont see those changes. any idea why?
from arcgis.gis import GIS
from arcgis.features import FeatureLayerCollection
# Connect to your ArcGIS Online organization or Portal for ArcGIS
gis = GIS("home")
# Access the hosted feature layer
item = gis.content.get("223afb0dadeb432d9ab1a661e1a8116f")
feature_layer_collection = FeatureLayerCollection.fromitem(item)
# Access the specific table within the feature layer
table = feature_layer_collection.tables[0] # Adjust the index if there are multiple tables
# Change the name and display name of the GUID field
fields = table.properties.fields
for field in fields:
if field["type"] == "esriFieldTypeGUID" and field["name"] == "furnitureguid":
print("Found the field with the name 'furnitureguid' and type 'esriFieldTypeGUID'.")
print("Updating the name and display name of the field to 'landassetsguid'.")
field["name"] = "landassetsguid"
field["alias"] = "Land Assets GUID" # Modify the display name
# Convert the fields list to a dictionary
fields_dict = [dict(field) for field in fields]
try:
table.manager.update_definition({"fields": fields_dict})
print("Successfully updated the name and display name of the GUID field.")
except Exception as e:
print(f"An error occurred while updating the field: {e}")
# Change the name and display name of the relationship
relationships = table.properties.relationships
for relationship in relationships:
if relationship["name"] == "Furniture":
print("Found the relationship with the name 'Furniture'.")
print("Updating the name and display name of the relationship to 'Land Assets'.")
relationship["name"] = "Land Assets"
relationship["name"] = "Land Assets" # Modify the display name
# Convert the relationships list to a list of dictionaries
relationships_dict = [dict(rel) for rel in relationships]
try:
table.manager.update_definition({"relationships": relationships_dict})
print("Successfully updated the name and display name of the relationship.")
print(f"An error occurred while updating the relationship: {e}")
/opt/conda/lib/python3.9/site-packages/arcgis/gis/__init__.py:703: UserWarning: You are logged on as Isabelle_B with an administrator role, proceed with caution.
warnings.warn(
