When setting up a geolocator and based on field input mapping, automatically set the 'Match with no zones' option.
The Create Locator tool will automatically set the "Match with no Zones" property to "Yes" if the locator is built with no administrative zones (city, state, postal, etc...). The Create Locator tool will default the property to "No" if any administrative zone is mapped when building the locator.
It is strongly recommended to map the administrative zones when building a locator and it is also strongly recommended that the "Match with no Zones" property is set to "No". With suggestions support in Pro the need for the "Match with no Zones" property is not as necessary because users have the ability to choose the suggested candidate without needing to enter the entire address or place. Setting "Match with no Zones" to "Yes" should only be done if there is a specific need that requires it.
@BradNiemandI opened a case because we were getting no results from ArcGIS Javascript 4.2x but in ArcGIS Pro and Webmaps we were receiving results. Going to the Geocoder Service Rest API, no results as well. We used a composite geolocator. One of the 5 geolocators should have come back with a result regardless of if two out of the 5 had Match with no zones set to No when it should be Yes. These locators were created in ArcGIS Pro 2.9. I'm wondering when this functionality came out because the "Match with no Zones" automatically being set didn't happen. The Composite Geocoder should have skipped that one locator and gone to the rest but it didn't. That's why I placed this in the ArcGIS Ideas page because the Geocoding option didn't actually get set automatically. Support Person Identified BUG-000148113 as a possible issue
Esri Case #03473800
Recap:
Sign in to post, follow content, and more. New here? Register for free.
