Adding a tool to manage numerous Label Classes.This tool should provide a sorting function, a search function and/or filter, and give us the ability to do global edits to numerous Label Classes at one time.
Hi Darwin,
Have you looked into the label summary and the labeling view of the contents pane?
the Label summary will provide you an overview of your label classes with warnings and also offers the ability to filter the information
https://pro.arcgis.com/en/pro-app/latest/help/mapping/text/label-summary.htm
the label view of the contents pane will provide you a complete view of your label classes and provide the ability to copy and paste the labeling properties between label classes and change properties for multiple label classes at the same time
https://pro.arcgis.com/en/pro-app/latest/help/mapping/map-authoring/contents-pane.htm
In ArcMap's label manager, the terminology "copy parameters" and "paste parameters" told the user exactly what was going to happen. Now in Pro's label view of the contents page there is "copy" and "paste". Copy what? The entire layer? The label class? The parameters?
Why not mimic what was done in ArcMap and its label manager so that migration is simpler?
In Pro the Copy copies all of the labeling properties. then with the Paste you can decide what you'd like to paste - everything, or just the placement properties for example
I see what you're saying, @WendyHarrison . Sorry I didn't find that. It would be a non-issue if ESRI had moved ArcMap to the 64-bit platform while continuing to fix and add things.
Sign in to post, follow content, and more. New here? Register for free.
