I have a table within my ArcGIS Pro application which I created using the below code:
table1 = arcpy.CreateTable_management(None, "TableName1")
table2 = arcpy.CreateTable_management(None, "TableName2")
arcpy.management.AddRelate("TableName1", "key1", "TableName2", "key2", "KeyRelation", "ONE_TO_MANY")
I am performing insert operations into this table every time I run a Python ToolBox which is done using the below code.
def truncate_place_table():
st1 = time.perf_counter()
arcpy.TruncateTable_management("TableName1")
arcpy.TruncateTable_management("TableName2")
arcpy.AddMessage(f"Table Truncation time taken: {time.perf_counter() - st1}")
return True
def insert_to_table():
with arcpy.da.InsertCursor("TableName1", INSERT_FIELD_NAMES) as cursor:
arcpy.AddMessage(f"insert_doc: {doc}")
cursor.insertRow(doc)
return True
The problem is that the table truncation takes more than a second to complete. If I do not include the table truncation operation, the `insertRow` command does not work.
Is there any way to speed up table truncation or alternative to flush and insert new records to table at a faster pace?
