// ***************************************************************************** // * EDIT FEATURES - MOVE, EDIT VERTICES, SCALE, ROTATE, OPTIONS * // ***************************************************************************** function createEditToolbar() { var activeFeatureLayer = null; var landuseLayerFL = map.getLayer("landuseLayer"); var militaryareasFL = map.getLayer("militaryareas"); editModifyFeaturesTools = new esri.toolbars.Edit(map); // ACTIVATE TOOLBAR WHEN CLICKING ON PLANTING SITES dojo.connect(landuseLayerFL, "onClick", function(evt) { dojo.stopEvent(evt); activateEditToolbar(evt.graphic); activeFeatureLayer = landuseLayerFL; }); // ACTIVATE TOOLBAR WHEN CLICKING ON PUBLIC TREE INVENTORY dojo.connect(militaryareasFL, "onClick", function(evt) { dojo.stopEvent(evt); activateEditToolbar(evt.graphic); activeFeatureLayer = militaryareasFL; }); // DEACTIVATE TOOLBAR dojo.connect(map,"onClick", function(evt){ editModifyFeaturesTools.deactivate(); }); // POST EDITS AFTER TOOL IS DEACTIVATED dojo.connect(editModifyFeaturesTools, "onDeactivate", function(editTool,graphic) { activeFeatureLayer.applyEdits(null, [graphic], null); alert("Feature successfully updated."); }); } // ACTIVATE TOOLBAR EDITING function activateEditToolbar(graphic) { var editTool = 0; if (dijit.byId("tool_move").checked) { editTool = editTool | esri.toolbars.Edit.MOVE; } if (dijit.byId("tool_vertices").checked) { editTool = editTool | esri.toolbars.Edit.EDIT_VERTICES; } if (dijit.byId("tool_scale").checked) { editTool = editTool | esri.toolbars.Edit.SCALE; } if (dijit.byId("tool_rotate").checked) { editTool = editTool | esri.toolbars.Edit.ROTATE; } // SPECIFY TOOLBAR OPTIONS var options = { allowAddVertices: dijit.byId("vtx_ca").checked, allowDeleteVertices: dijit.byId("vtx_cd").checked, uniformScaling: dijit.byId("uniform_scaling").checked }; editModifyFeaturesTools.activate(editTool, graphic, options); } // ***************************************************************************** // * DELETE FEATURES * // ***************************************************************************** function editingDeleteFeature(results) { var layers = dojo.map(results, function (result) { return result.layer; }); // DELETE FEATURE USING ONCLICK dojo.forEach(layers, function (deleteFeatureslLayer) { dojo.connect(deleteFeatureslLayer, "onClick", function (evt) { dojo.stopEvent(evt); // DELETE FEATURE IS DELETE BUTTON IS CHECKED (ACTIVE) if (dijit.byId("tool_delete").checked) { deleteFeatureslLayer.applyEdits(null, null, [evt.graphic], function () { operation = new esri.dijit.editing.Delete({ featureLayer: deleteFeatureslLayer, deletedGraphics: [evt.graphic] }); // ALERT WHEN FEATURE IS DELETED alert("Feature deleted.") }); } }); }); }
