I'm using the 3D toolbox in Experience Builder, the shadowcast analysis does not clear when 'Clear Analysis' is clicked. The shadows then stay permanently on the screen. Is this a bug? It didn't use to do this.
Same / similar problem as in this Instant app issue https://community.esri.com/t5/arcgis-instant-apps-ideas/shadowcast-widget-error-in-3d-viewer/idi-p/1268476
@JoCondliffe
Thanks for your feedback. This should be a regression bug in 3D Toolbox widget. We will fix asap.
Thank you. The quicker the better, it makes the tool and the whole app unusable by my customers who need it to help make planning decisions.
Shadow cast now works in Instant apps, but not in EB.There are two bugs:
Both theese things are fine in Instant Apps
Hi @SveinungBertnesRåheim ,
I am not able to repro either of the issue in ExB now. Would you be able to try again?
Thanks,Wei
There has been an evolution in the problems:Clear now removes the analysis from the map. Date selector is still the same. You have to change the size of the shadow cast widget frame to be able to see the month and date selector.And!After clicking "Clear analysis", the results are removed from the map and the shadow cast dialog is closed, back to 3d toolbox. If I open the shadow cast again, nothing happens. No results are prodused. I have to refresh my browser to get it work again.So still a way to go, it seems!The widget is available in this public EB-setup:https://experience.arcgis.com/experience/2fbdc0168cac4742a6331f02c77e13bc/page/3d-modell/
