I am trying to use the ListDatabaseSequences function and when using a SDE connection, I always get following error: OSError: Could not open SDE workspace. If I use a FGDB connection it's working fine.
If I use the same SDE connection with the ListDomains function everything works just fine.
I am testing the code "as is" from the AGS Pro on-line documentation.
I am using AGS Pro 3.1.3
import arcpy
#this works for ListDatabaseSequences
#gdbFGDB = r"D:\droberge\temp\coa_GIS\dr_testArcade.gdb"
#this works for ListDomains
gdbSDE = r"D:\droberge\programs\GIS_PRO\dr_coa_MASTER\coaUNWater_coa_gis.sde"
sequences = arcpy.da.ListDatabaseSequences(gdbSDE)
domains = arcpy.da.ListDomains(gdbSDE)
try:
for seq in sequences:
print("------------------------")
print('Sequence name: {}'.format(seq.name))
print('Sequence start value: {}'.format(seq.startValue))
print('Sequence increment value: {}'.format(seq.incrementValue))
print('Sequence current value: {}'.format(seq.currentValue))
## for domain in domains:
## print(f"Domain name: {domain.name}")
## if domain.domainType == "CodedValue":
## coded_values = domain.codedValues
## for val, desc in coded_values.items():
## print(f"{val} : {desc}")
## elif domain.domainType == "Range":
## print(f"Min: {domain.range[0]}")
## print(f"Max: {domain.range[1]}")
except:
print(" we are in the except section... no bueno")
arcpy.AddMessage(arcpy.GetMessages(2))
print(arcpy.GetMessages(2))
print("Process is over!")
This is the error
Any help would be much appreciated.
Thanks!
