for lyr in layerlist: # if the long layer name does not equal the short layer name if lyr.longName != lyr.name: #Find Layer with name == "flow" if lyr.name.lower() == "flow": #Pan to Extent of Flow Layer df.extent = lyr.getExtent() print extent print lyr.name.lower()
lyr = arcpy.mapping.ListLayers(mxd, "Flow", df)[0] df.extent = lyr.getExtent() arcpy.RefreshActiveView()
This should be all you need unless you have some other things going on not in the code you posted.lyr = arcpy.mapping.ListLayers(mxd, "Flow", df)[0] df.extent = lyr.getExtent() arcpy.RefreshActiveView()Edit: You are just missing the arcpy.RefreshActiveView() I am thinking.
#Import the arcpy package import arcpy #Assign the Western States Mapping Document to variable mxd mxd = arcpy.mapping.MapDocument("CURRENT") #Create a data driven pages object using "mxd" and assign it to variable "ddp" #ddp = mxd.dataDrivenPages #Create a list of all text elements in the map layout textlist = arcpy.mapping.ListLayoutElements(mxd,"TEXT_ELEMENT") #Cycle through the text elements for txt in textlist: #When you find one whose text says "MAP SUBTITLE"... if txt.text == r"MAP SUBTITLE": #....Assign it to variable "subtitle" subtitle = txt #Create a list of the layers in the map document layerlist = arcpy.mapping.ListLayers(mxd) df = arcpy.mapping.ListDataFrames(mxd)[0] #Cycle through each layer for lyr in layerlist: # if the long layer name does not equal the short layer name if lyr.longName != lyr.name: #Find Layer with name == "flow" if lyr.name.lower() == "flow": #Pan to Extent of Flow Layer lyr = arcpy.mapping.ListLayers(mxd, "flow",df)[0] df.extent = lyr.getExtent() df.scale = df.scale * 1.15 arcpy.RefreshActiveView() #If the layer is NOT visible... if lyr.visible == False: #...Turn the layer on lyr.visible = True list2 = arcpy.mapping.ListLayers(lyr) #Change the Subtitle text element to match the layer's name subtitle.text = lyr.name #Create a string showing the path of the pdf that will be written out pdfpath = "C://Users//user//Desktop//PDF_TEMP//" + lyr.name + r" mapbook.pdf" #Print that we are exporting a mapbook print "Exporting " + pdfpath + "....." #Export the mapbook to pdf arcpy.mapping.ExportToPDF(mxd, pdfpath) #Turn the layer off again lyr.visible = False #Delete variables to clean up memory usage del mxd print "Done!"
lyrlist = arcpy.mapping.ListLayers(mxd, "*flow*")
Are you having a problem with the PDF not exporting at the correct extent, or in your mxd the layer not going to the correct extent?These flow layers are in a group layer, that's why I assume you are testing for the long name? You can restrict the layer list by just doing something like this.lyrlist = arcpy.mapping.ListLayers(mxd, "*flow*")
#Import the arcpy package import arcpy #Assign the Western States Mapping Document to variable mxd mxd = arcpy.mapping.MapDocument("CURRENT") #Create a data driven pages object using "mxd" and assign it to variable "ddp" #ddp = mxd.dataDrivenPages #Create a list of all text elements in the map layout textlist = arcpy.mapping.ListLayoutElements(mxd,"TEXT_ELEMENT") #Cycle through the text elements for txt in textlist: #When you find one whose text says "MAP SUBTITLE"... if txt.text == r"MAP SUBTITLE": #....Assign it to variable "subtitle" subtitle = txt #Create a list of the layers in the map document layerlist = arcpy.mapping.ListLayers(mxd) df = arcpy.mapping.ListDataFrames(mxd)[0] #Cycle through each layer for lyr in layerlist: # if the long layer name does not equal the short layer name if lyr.longName != lyr.name: #Find Layer with name == "flow" if lyr.name.lower() == "flow": lyrslist2 = arcpy.mapping.ListLayers(mxd, "*flow*") #Pan to Extent of Flow Layer for lyr in lyrslist2: df.extent = lyrs.getExtent() #df.scale = df.scale * 1.15 arcpy.RefreshActiveView() #If the layer is NOT visible... if lyr.visible == False: #...Turn the layer on lyr.visible = True list2 = arcpy.mapping.ListLayers(lyr) #Change the Subtitle text element to match the layer's name subtitle.text = lyr.name #Create a string showing the path of the pdf that will be written out pdfpath = "C://Users//atimpson//Desktop//DDP_TEMP//" + lyr.name + r" mapbook.pdf" #Print that we are exporting a mapbook print "Exporting " + pdfpath + "....." #Export the mapbook to pdf arcpy.mapping.ExportToPDF(mxd, pdfpath) #Turn the layer off again lyr.visible = False #Delete variables to clean up memory usage del mxd print "Done!"
if "flow" in lyr.name.lower():
#Import the arcpy package import arcpy #Assign the Western States Mapping Document to variable mxd mxd = arcpy.mapping.MapDocument("CURRENT") #Create a data driven pages object using "mxd" and assign it to variable "ddp" #ddp = mxd.dataDrivenPages #Create a list of all text elements in the map layout textlist = arcpy.mapping.ListLayoutElements(mxd,"TEXT_ELEMENT") #Cycle through the text elements for txt in textlist: #When you find one whose text says "MAP SUBTITLE"... if txt.text == r"MAP SUBTITLE": #....Assign it to variable "subtitle" subtitle = txt #Create a list of the layers in the map document layerlist = arcpy.mapping.ListLayers(mxd, "*flow*") df = arcpy.mapping.ListDataFrames(mxd)[0] #Cycle through each layer for lyr in layerlist: # if the long layer name does not equal the short layer name if lyr.longName != lyr.name: #Find Layer with name == "flow" if "flow" in lyr.name.lower(): #Pan to Extent of Flow Layer df.extent = lyr.getExtent() #df.scale = df.scale * 1.15 arcpy.RefreshActiveView() #If the layer is NOT visible... if lyr.visible == False: #...Turn the layer on lyr.visible = True #Change the Subtitle text element to match the layer's name subtitle.text = lyr.name #Create a string showing the path of the pdf that will be written out pdfpath = "C:/test/pdf/" + lyr.name + r" mapbook.pdf" #Print that we are exporting a mapbook print "Exporting " + pdfpath + "....." #Export the mapbook to pdf arcpy.mapping.ExportToPDF(mxd, pdfpath) #Turn the layer off again lyr.visible = False #Delete variables to clean up memory usage del mxd print "Done!"
arcpy.SelectLayerByAttribute_management(layer, "NEW_SELECTION")
import arcpy import time arcpy.env.overwriteOutput = True mxd = arcpy.mapping.MapDocument("CURRENT") textlist = arcpy.mapping.ListLayoutElements(mxd,"TEXT_ELEMENT") for txt in textlist: if txt.text == r"MAP SUBTITLE": subtitle = txt layerlist = arcpy.mapping.ListLayers(mxd) df = arcpy.mapping.ListDataFrames(mxd)[0] for lyr in layerlist: if lyr.longName != lyr.name: if "flow" in lyr.name.lower(): arcpy.SelectLayerByAttribute_management(lyr, "NEW_SELECTION") df.zoomToSelectedFeatures() arcpy.SelectLayerByAttribute_management(lyr, "CLEAR_SELECTION") df.scale = df.scale * 1.15 arcpy.RefreshActiveView() if lyr.visible == False: lyr.visible = True subtitle.text = lyr.name time.sleep(3) pdfpath = "C://Users//user//Desktop//DDP_TEMP//" + lyr.name + r" mapbook.pdf" print "Exporting " + pdfpath + "....." arcpy.mapping.ExportToPDF(mxd, pdfpath) lyr.visible = False del mxd, df print "Done!"
