Also, instead of creating a list of each "TWACs_NUMBER", and running a seperate cursor for each one, just run a single cursor and store the lists in a dictionary, where each twacNo is a key and each key points to a list of meterNos. In v10.1 this would look like:twacDict = {} searchRows = arcpy.da.SearchCursor(table, ["TWACs_NUMBER","METER_NUMBER"]) for searchRow in searchRows: twacNo, meterNo = searchRow if twacNo in twacDict: twacDict[twacNo].append(meterNo) else: twacDict[twacNo] = [meterNo] del searchRow, searchRows twackList = twacDict.keys() twackList.sort() for twacNo in twackList: meterList = twacDict[twacNo] #make a graph here, since you now have a hook to the twacNo and it's list of meterNos
This table "in_memory\table_sel" you create will persist until you close the instance it was created in.
I would find it more likely your log file is the issue. Try disabling logging and running it a few times to see if you get the same slow downs. Also, are you closing the instance of python this script is running in between executions? The in_memory workspace won't clear properly until you terminate the instance it was executed in or you clear it explicitly.
# Name: Electric Meter Demand Graphs - Usage.py # Description: Python script to take a single TWACs Meter and create a Usage Graphs per Feeder # Date Created: Tuesday, September 17th, 2013 @ 1:20 PM # Date Modified: Tuesday, September 17th, 2013 @ 1:20 PM # Author: C. Wafstet #94 - Modern Electric Water Company (Spokane, WA) import arcpy import arcpy import logging from arcpy import env env.overwriteOutput = 1 env.workspace = r"C:\MEWCo GIS System\Electric System\MEWCo_Electric_Model-LOCAL.gdb" table = "SERVICE_METERS_DEMAND_F1FEEDER_ABC" list = [] # if run in ArcGIS Desktop, show messages, also print to log def log(method, msg): print msg method(msg) logging.basicConfig( level=logging.INFO, format='%(asctime)s %(levelname)-s %(message)s', datefmt='%a, %d %b %Y %H:%M:%S', filename='MakeGraph.log', filemode='w' ) log(logging.info, "Creation of Graphs Started") rows = arcpy.SearchCursor(table) for row in rows: list.append(row.TWACs_NUMBER) del row, rows # Remove duplicates from list list = dict.fromkeys(list) list = list.keys() for n in list: arcpy.TableSelect_analysis(table, r"in_memory\table_sel", "TWACs_NUMBER = " + str(n)) # Get TWACs_Number value for row in arcpy.SearchCursor(r"in_memory\table_sel"): METER_NUMBER = row.getValue("METER_NUMBER") out_graph_name = n out_graph_pdf = r"C:\MEWCo GIS System\Electric Graphs\Electric Meters\Usage Graphs\F-1 Feeder" + "\\" + str(n)[:-2] + "-Usage" + ".pdf" input_template = r"C:\MEWCo GIS System\Electric Graphs\GIS Graph Temps\ELECTRIC METER DEMAND - KWH USAGE.grf" input_data = r"in_memory\table_sel" # Create the Graph graph = arcpy.Graph() # Add a Vertical Bar series to the graph - KWH Usage graph.addSeriesBarVertical(input_data, "KWH_USAGE") # Specify the title of the Left Axis graph.graphAxis[0].title = "KWH_USAGE" # Specify the title of the Bottom Axis graph.graphAxis[2].title = "BILLING_PERIOD" # Specify the title of the Graph graph.graphPropsGeneral.title = "KWH Usage by Electric TWACs Number: " + METER_NUMBER # Output a graph, which is created in-memory arcpy.MakeGraph_management(input_template, graph, out_graph_name) # Save the graph as an .PDF arcpy.SaveGraph_management(out_graph_name, out_graph_pdf, "MAINTAIN_ASPECT_RATIO", 600, 375) log(logging.info, "Creation of Graphs Complete")
