Hi
I know I can export a pdf of the route from the directions widget by using the print widget but is there a way for this to include the written directions as well as a map?
Sarah
Hi @sarrahm22 ,
Here are two potential workarounds:
One is to publish your own print service template with a long custom text element. In Experience Builder, after obtaining the written directions, you can copy and paste them into the custom text element's input box. However, you would need to apply custom styling in ArcGIS Pro and add "\n" to create new lines in the written directions.
Here is a sample print result:
The other option is to use the browser's print function. I have attached a sample print result from this approach in this post. Some key points to note with this option:
Add the map and direction widget individually to a scrolling page
Set both the direction widget and container elements to Auto-height
