Hi all, i'm using the TemplatePicker widget in the editor and want to have only one item and not the 4 i have in the layer . has any one have an idea . i have tried the "ITEMS" instead of the layer with no luck.i also tried to use jquery selector to hide the other - no luck there either.$('#ThePicker td[idx!="2"]').css("display", "none");if anyone has suggestion ,i'll be happy to hear.thanksiris
function initEditor(results) { var layerInfosWildfire = array.map(results.layers, function(result) { return { featureLayer : result.layer }; }); var layersWildfire = [results.layers[1].layer] var tpCustom = new TemplatePicker({ featureLayers: layersWildfire, columns: 2 }, "divLeft") tpCustom.startup(); var editorSettings = { map: map, geometryService: new GeometryService("http://server/arcgis/rest/services/Utilities/Geometry/GeometryServer"), layerInfos: layerInfosWildfire, templatePicker: tpCustom, } var editorParams = { settings: editorSettings } widgetEditor = new Editor(editorParams, "divTop") widgetEditor.startup(); };
