We are currently using Experience Builder for a couple apps I built that use the Map widget to select an asset and pull attributes into a Survey widget. Our issue is that when the asset is selected, the survey point isn't snapping to the asset. If they don't zoom in tight enough, it has put the point as far as 200 ft from the asset. Is there a way to turn on snapping in the Map widget to avoid this issue? Some of our guys struggle with the technology, so I'm hoping we can find a solution that keeps it easy for them.
