I have various multi layered vector line / polygon symbols that I have authored in ArcGIS Pro, and have published to use in Map Viewer. One example is a black line with markers along it, with a white casing around both the line and markers to provide contrast. In ArcGIS Pro, it looks like this:
However, on the web in Map Viewer, despite the order in the same vector symbol in the chooser being in the same order, the white marker background renders in front of the black line that should be on top of it:
This seems to also happen with polygon symbology with similar configurations.
Any ideas about how to make it work correctly, or is it a bug that needs fixing? Thanks.
