The coordinate system of my data frame is set to British National Grid, however when I try to add a grid (graticule) it is always projected using WGS84. How can I add a grid using the correct projection?
ArcGIS version is 10.2.1.3497.
I suspect that the data are in wgs84, did you follow the steps as outlined here
Thanks for the pointer Dan, the answer was to use measured projection instead of graticule.
