Are you talking about the REST API? Find does restrict results only for the USA when you pass in sourceCountry. Currently the suggest API doesn't support sourceCountry as a parameter so it will not restrict suggestions when passing in sourceCountry.Suggest doc:http://resources.arcgis.com/en/help/arcgis-rest-api/#/Working_with_suggestions/02r300000238000000/Find doc:http://resources.arcgis.com/en/help/arcgis-rest-api/#/Single_input_field_geocoding/02r300000015000000/As you can see, the parameter exists on the Find method but not the Suggest method.Brad
Can you give an example of what you are doing and what you are getting?Brad
