Hello, I have different methods within the same script tool how I can apply filter so that the user will select different method and run code
If I understand you correctly, you have a function with 3 parameters:
To use this function inside a script tool, you have to define 3 parameters for the tool:
In the method parameter, define a filter list with valid method names. This way, you have a dropdown list with predefined things like "warp", "edge", etc.
Then you change your script:
<SPAN class="comment token"># imports</SPAN> <SPAN class="comment token"># get the script parameters</SPAN> raster_param <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> scale_param <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># convert to int or float as needed</SPAN> method_param <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># this parameter has a filter list,</SPAN> <SPAN class="comment token"># so you know it can only be "warp" or "edge".</SPAN> <SPAN class="comment token"># define your function (I think you already have that)</SPAN> <SPAN class="keyword token">def</SPAN> <SPAN class="token function">your_function</SPAN><SPAN class="punctuation token">(</SPAN>raster<SPAN class="punctuation token">,</SPAN> scale<SPAN class="punctuation token">,</SPAN> method<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># stuff</SPAN> <SPAN class="keyword token">if</SPAN> method <SPAN class="operator token">==</SPAN> <SPAN class="string token">"warp"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># warp implementation</SPAN> <SPAN class="keyword token">if</SPAN> method <SPAN class="operator token">==</SPAN> <SPAN class="string token">"edge"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># edge implementation</SPAN> <SPAN class="comment token"># more stuff</SPAN> <SPAN class="comment token"># call your function</SPAN> your_function<SPAN class="punctuation token">(</SPAN>raster_param<SPAN class="punctuation token">,</SPAN> scale_param<SPAN class="punctuation token">,</SPAN> method_param<SPAN class="punctuation token">)</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thanks for your reply, Sure I am trying to use ready function that need arguments such (raster, scale , and method)
what I need the user to select the method from drop down menu and run the tool ?
Mina Alsaad, I read your question and your responses, and I am having a hard time figuring out your question. I realize there may be a language barrier occurring, but that makes it even more important to provide specifics and examples rather than speaking in general.
Dan Patterson What I meant only I want to change one parameter and run the tool?
Dan Patterson Thanks for your reply, what I want to do to call one function rescale (input, mode, other parameters)
inside mode there is different method {edge, warp,}, if the user select one of the method it will be different result ?
for one of your parameters, define it as a text parameter and make a value list with your options.
For each option, create a def that performs the task
<SPAN class="keyword token">import</SPAN> blah method <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># a value list of the method names</SPAN> params <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">def</SPAN> <SPAN class="token function">method1</SPAN><SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"""method1 functionality"""</SPAN> Do stuff <SPAN class="keyword token">return</SPAN> something <SPAN class="keyword token">def</SPAN> <SPAN class="token function">method2</SPAN><SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"""method2 functionality"""</SPAN> Do stuff <SPAN class="keyword token">return</SPAN> something <SPAN class="keyword token">if</SPAN> method <SPAN class="operator token">==</SPAN> <SPAN class="string token">"first"</SPAN><SPAN class="punctuation token">:</SPAN> result <SPAN class="operator token">=</SPAN> method1<SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN> result <SPAN class="operator token">=</SPAN> method2<SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Here is the amazing result : {}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
