I am working with ArcGIS Pro 3.1 Notebooks. As the GIS Administrator, I have admin and read-only sde connection files to various enterprise geodatabases. When I set arcpy.env.workspace to an admin connection file to one of these geodatabases, some List_ methods return None or [] when they, in fact, contain data that the admin can see. In fact, the admin owns some of these feature classes. I can see them fine in Catalog.
For example, an admin connection to a geodatabase full of rasters yields None when arcpy.ListRasters is called. Or when using an admin to another admin connection, arcpy.ListFeatureClasses yields []. However, when I set arcpy.env.workspace to a read-only connection file to these geodatabases, the arcpy.List_ methods return good data.
These enterprise geodatabases are at version 10.9.1.2.9.
What might explain why the List_ methods return None or [] when arcpy.env.workspace is set to an .sde file containing admin credentials, but contain good data when using an .sde file containing read-only credentials?
