I've created the French field in my d_rename table to translate my UN electric database, the problem is that when I try to apply the asset package, I get these errors, knowing that I've modified these fields one by one (I've emptied their translation fields and I've put the real bypass) but it doesn't work.
Have you ever had this kind of problem? Do you have any help on how it could be caused?
The asset package has the following errors (48/48):
Item Field OID Value Message Level
0 CommunicationEdgeObject LENGTH NaN NaN This field name is reserved on some database platforms warning
1 CommunicationEdgeObject IGNORE NaN NaN This field name is reserved on some database platforms warning
2 CommunicationEdgeObject THIS_ATTRIBUTE_IS_NECESSARY_TO_ NaN NaN This field is too long for some database platforms warning
3 CommunicationEdgeObject DOCUMENTEDBY_REQUIREMENTSPECIFI NaN NaN This field is too long for some database platforms warning
4 CommunicationEdgeObject TENSIONADJUSTMENTBYTEMPERATURE NaN NaN This field is too long for some database platforms warning
5 CommunicationJunction IGNORE NaN NaN This field name is reserved on some database platforms warning
6 CommunicationLine LENGTH NaN NaN This field name is reserved on some database platforms warning
7 CommunicationLine IGNORE NaN NaN This field name is reserved on some database platforms warning
8 CommunicationLine THIS_ATTRIBUTE_IS_NECESSARY_TO_ NaN NaN This field is too long for some database platforms warning
9 CommunicationLine DOCUMENTEDBY_REQUIREMENTSPECIFI NaN NaN This field is too long for some database platforms warning
10 CommunicationLine TENSIONADJUSTMENTBYTEMPERATURE NaN NaN This field is too long for some database platforms warning
11 ElectricAssembly IGNORE NaN NaN This field name is reserved on some database platforms warning
12 ElectricDevice IGNORE NaN NaN This field name is reserved on some database platforms warning
13 ElectricDevice MEASUREMENTDISTANCEINTERVALCOOL NaN NaN This field is too long for some database platforms warning
14 ElectricDevice RATEDOPERATINGPOWERNEUTRALPOINT NaN NaN This field is too long for some database platforms warning
15 ElectricDevice CLUSTER NaN NaN This field name is reserved on some database platforms warning
16 ElectricDevice MAXCONTINUOUSOPERATINGVOLTAGEB1 NaN NaN This field is too long for some database platforms warning
17 ElectricDevice MAXCONTINUOUSOPERATINGVOLTAGEB2 NaN NaN This field is too long for some database platforms warning
18 ElectricDevice MAXCONTINUOUSOPERATINGVOLTAGEB3 NaN NaN This field is too long for some database platforms warning
19 ElectricDevice MAXCONTINUOUSOPERATINGVOLTAGEB4 NaN NaN This field is too long for some database platforms warning
20 ElectricEdgeObject IGNORE NaN NaN This field name is reserved on some database platforms warning
21 ElectricJunction IGNORE NaN NaN This field name is reserved on some database platforms warning
22 ElectricJunctionObject IGNORE NaN NaN This field name is reserved on some database platforms warning
23 ElectricLine IGNORE NaN NaN This field name is reserved on some database platforms warning
24 ElectricLine LENGTH NaN NaN This field name is reserved on some database platforms warning
25 ElectricLine DOCUMENTEDBY_REQUIREMENTSPECIFI NaN NaN This field is too long for some database platforms warning
26 ElectricLine TENSIONADJUSTMENTBYTEMPERATURE NaN NaN This field is too long for some database platforms warning
27 StructureBoundary IGNORE NaN NaN This field name is reserved on some database platforms warning
28 StructureBoundary LENGTH NaN NaN This field name is reserved on some database platforms warning
29 StructureBoundary CLUSTER NaN NaN This field name is reserved on some database platforms warning
30 StructureBoundarySF IGNORE NaN NaN This field name is reserved on some database platforms warning
31 StructureBoundarySF LENGTH NaN NaN This field name is reserved on some database platforms warning
32 StructureEdgeObject IGNORE NaN NaN This field name is reserved on some database platforms warning
33 StructureEdgeObject POSITIVESEQUENCESYSTEMRESISTANC NaN NaN This field is too long for some database platforms warning
34 StructureEdgeObject POSITIVESEQUENCESYSTEMREACTANCE NaN NaN This field is too long for some database platforms warning
35 StructureEdgeObject POSITIVESEQUENCESYSTEMCAPACITAN NaN NaN This field is too long for some database platforms warning
36 StructureEdgeObject MEASUREDPOSITIVESEQUENCESYSTEMR NaN NaN This field is too long for some database platforms warning
37 StructureJunction IGNORE NaN NaN This field name is reserved on some database platforms warning
38 StructureJunction LENGTH NaN NaN This field name is reserved on some database platforms warning
39 StructureJunctionObject IGNORE NaN NaN This field name is reserved on some database platforms warning
40 StructureJunctionSF IGNORE NaN NaN This field name is reserved on some database platforms warning
41 StructureJunctionSF THIS_ATTRIBUTE_IS_NECESSARY_TO_ NaN NaN This field is too long for some database platforms warning
42 StructureLine LENGTH NaN NaN This field name is reserved on some database platforms warning
43 StructureLine IGNORE NaN NaN This field name is reserved on some database platforms warning
44 StructureLine DOCUMENTEDBY_REQUIREMENTSPECIFI NaN NaN This field is too long for some database platforms warning
45 StructureLineSF LENGTH NaN NaN This field name is reserved on some database platforms warning
46 StructureLineSF IGNORE NaN NaN This field name is reserved on some database platforms warning
47 D_Rename rename_translation_fr 1846.0 37.0 Length of rename value must be <= 32 characters error
