I have an application uses basemapGallery, I just realized two of the basemaps have zoomlevel setting diffferent from the rest basemaps. Is it normal? Is there anyway to make the same zoomlevel for all basemaps?
Thanks for the information. Your link is helpful.
But I am using only ArcGIS API.Within ArcGIS API, depending on which base-map I loaded in, the zoom level is different. I guess it was due to the basemap format "The basemap styles service provides basemaps with layers formatted as either image tile layers or vector tile layers. When you use a basemap in your application, the scale of your zoom level will vary based on the type of layer the basemap uses. "
According to this API page:
I guess that's the reason of your problem.
Sorry, i dont have an answer, but I too have that issue with a custom "Home" button i built. the "view.zoom" level is different between my 2 basemaps. meaning clicking "Home" zooms differently depending on which basemap i have open.
Just echoing your issue. good luck!
p
