Hello, I am just stack with preparing Arcade expression for immediate calculation. By the immediate calculation, I would like to update three fields based on a table's attributes via a key field when new creation or update of a existing feature.
I have prepared a code as per below but I will get an error as per below when I create a new feature. If anyone know a solution for this, match appreciated.
// Rule for asset_july_2023
// triggers: insert, update
// field: no select
// value of shared field
var key = $feature["Asset_NAME"]
// search for related features in tbl_asset_info feature class
var assInfFS = FeatureSetByName($datastore, "tbl_asset_info", ["*"], false)
var assInfFilter = Filter(assInfFS, "Asset_NAME = <a href="https://community.esri.com/t5/user/viewprofilepage/user-id/301813">@Key</a>")
var assTabList = []
var counter = 0
var numAsset = Count(assInfFilter)
if (numAsset > 0) {
for (var asst in assInfFilter) {
assTabList[counter] = {
'attributes': {
'ASSET_ID': asst.ASSET_ID,
'TYPE': asst.TYPE,
'VALUE': asst.VALUE
counter++
return {
'edit': [{
'className': 'asset_july_2023',
'adds':assTabList,
'updates': assTabList
} else {
return 'No common asset in the asset info table.'
