Hi
Can anybody help me to understand why one of our users is getting the following sync error? What exactly does the error mean and what causes it?
'Error while handling start sync geodatabase on the server’.
Hello @LouiseHarris1 ,
Thank you for posting! I did some research on this and wanted to ask you some further questions:
Are you using ArcGIS Online or ArcGIS Enterprise?
Through my research, I found some resources that are related to the 'Error while handling start sync geodatabase on the server’. One of the resources notes that the possible issue may be a manual removal of one of the replicas:
"The answer is it does prevent Field Maps from syncing ALL of the layers, if one or more of the replicas is missing for any layer, even it the layer has no edits to push up. I was hoping it would sync the editable layers just fine and then just skip or ignore any missing replicas for the reference data, since there were no edits for them to be pushed."
We're using ArcGIS Online. Below are the errors that appear in the log file. While they got sync errors for some layers the layer with the edits in did sync.
Job error 22 Propagated error. Error while handling start sync geodatabase on the server
Wed Sep 13 16:10:56 GMT+01:00 2023 : [SYNC] - [e77b3d368dd6459c842d3d5e27a18f3b] - Message 38/45: Layer result: Sync failed. Name: NRW_PH2_Lowland_Grassland_quadrats_2020, LayerID: 0, TableName: Phase_2_Lowland_Grassland_quadrats_2020, URL: https://services.arcgis.com/hQoYDJEEJMaPw8Sy/arcgis/rest/services/NRW_PH2_Lowland_Grassland_quadrats_2020/FeatureServer/0 Job error 22 Propagated error. Error while handling start sync geodatabase on the server.Wed Sep 13 16:10:56 GMT+01:00 2023 : [SYNC] - [e77b3d368dd6459c842d3d5e27a18f3b] - Message 39/45: Layer result: Sync failed. Name: NRW_PH2_Lowland_Grassland_mospolys_2020, LayerID: 0, TableName: Phase_2_Lowland_Grassland_mospolys_2020, URL: https://services.arcgis.com/hQoYDJEEJMaPw8Sy/arcgis/rest/services/NRW_PH2_Lowland_Grassland_mospolys_2020/FeatureServer/0 Job error 22 Propagated error. Error while handling start sync geodatabase on the server.Wed Sep 13 16:10:56 GMT+01:00 2023 : [SYNC] - [e77b3d368dd6459c842d3d5e27a18f3b] - Message 36/45: Sync geodatabase: Succeeded. URL: https://services.arcgis.com/hQoYDJEEJMaPw8Sy/arcgis/rest/services/Sites_of_Special_Scientific_Interest/FeatureServerWed Sep 13 16:10:56 GMT+01:00 2023 : [SYNC] - [e77b3d368dd6459c842d3d5e27a18f3b] - Message 37/45: Layer result: Sync failed. Name: NRW_PH2_Lowland_Grassland_veg_2020, LayerID: 0, TableName: PH2_Lowland_Grassland_veg_2020, URL: https://services.arcgis.com/hQoYDJEEJMaPw8Sy/arcgis/rest/services/NRW_PH2_Lowland_Grassland_veg_2020/FeatureServer/0 Job error 22 Propagated error. Error while handling start sync geodatabase on the server.Wed Sep 13 1
Wed Sep 13 16:08:46 GMT+01:00 2023 : [SYNC] - [e77b3d368dd6459c842d3d5e27a18f3b] - Error syncing map: nullWed Sep 13 16:08:46 GMT+01:00 2023 : [SYNC] - [e77b3d368dd6459c842d3d5e27a18f3b] - Layer: NRW_PH2_Lowland_Grassland_mospolys_2020 Error: status code: 404, reason phrase: Unable to synchronize replica. : Error while handling start sync geodatabase on the serverWed Sep 13 16:08:46 GMT+01:00 2023 : [SYNC] - [e77b3d368dd6459c842d3d5e27a18f3b] - Layer: NRW_PH2_Lowland_Grassland_quadrats_2020 Error: status code: 404, reason phrase: Unable to synchronize replica. : Error while handling start sync geodatabase on the serverWed Sep 13 16:08:46 GMT+01:00 2023 : [SYNC] - [e77b3d368dd6459c842d3d5e27a18f3b] - Layer: NRW_PH2_Lowland_Grassland_veg_2020 Error: status code: 404, reason phrase: Unable to synchronize replica. : Error while handling start sync geodatabase on the server
Hi @LouiseHarris1 ,Did you ever find a solution to this ? We are experiencing the same issue. Thank you !
I am experiencing this issue as well. Would be great to hear more. Thank you!
Hi @LouiseHarris1
Has the schema changed in the online map whilst offline areas have been created?
Any layers removed or added?
If so you it might be recommended to retrieve the offline areas from this workflow Access offline edits from ArcGIS Field Maps directly from an iOS or Android device
