Hello.
I am having no luck finding a python snippet or example of how to list out privileges for the geodatabase. ChatGPT hasn't provided accurate coding either. If anyone can share how to do this then I would be very appreciative. We use SQL server.
Thank you.
For anyone using Oracle, here's a post that uses a SQL query to list table privileges:How to audit table permissions as a non-DBA
select table_name, grantee , max(sel) sel, max(ins) ins , max(upd) upd, max(del) del, case when max(other_privs) is not null then 'other' end other_privs, listagg(other_privs,',') within group (order by other_privs) as list_of_other_privs from (select table_name, grantee, case when privilege='SELECT' then 'y' end sel, case when privilege='INSERT' then 'y' end ins, case when privilege='UPDATE' then 'y' end upd, case when privilege='DELETE' then 'y' end del, case when privilege not in ('SELECT', 'INSERT','UPDATE','DELETE') then privilege end other_privs from user_tab_privs ) group by table_name, grantee order by table_name, grantee
You could make a similar post (but for SQL Server) on Stack Overflow or DBA Stack Exchange, and likely get a good answer.
You can use SQL Server Management Studio to see the permissions.Example:
--Verify role permissionsselect dp.NAME AS principal_name,dp.type_desc AS principal_type_desc,o.NAME AS object_name,p.permission_name,p.state_desc AS permission_state_descfrom sys.database_permissions pleft OUTER JOIN sys.all_objects oon p.major_id = o.OBJECT_IDinner JOIN sys.database_principals dpon p.grantee_principal_id = dp.principal_idwhere dp.NAME = 'gis_sde_owner'GO
--Verify User permissionsselect USER_NAME(p.grantee_principal_id) AS principal_name,dp.type_desc AS principal_type_desc,p.class_desc,OBJECT_NAME(p.major_id) AS object_name,p.permission_name,p.state_desc AS permission_state_descfrom sys.database_permissions pinner JOIN sys.database_principals dpon p.grantee_principal_id = dp.principal_idwhere USER_NAME(p.grantee_principal_id) = 'sde'GOI hope this helps.
@ShariF - see this python script example, it might give you some ideas.https://gis.stackexchange.com/questions/73991/checking-current-user-privileges-for-arcsde-dataset-with-arcpyThis article is quite old though. But take a look at the arcpy API documentation, it might have some new method available.https://developers.arcgis.com/python/api-reference/
If you do not find what you are looking for then I encourage you to open a support ticket with Esri Technical Support.
Thank you. I'm a newbie with SQL server studio and will give this a try.
Thank you. I found that article too but had no luck getting it to work. Maybe with arcpy.ARCSDESQExecute and the previous answer provided I can get something working.
