Is it possible to set the OpenItemDialog to show only local items and not show anything from the portal?
usually, by default, Portal isnt shown - at least in my case on v3.1:
OpenItemDialog itemDlg = new OpenItemDialog { Title = "Open Files", InitialLocation = @"E:\Data\Test", MultiSelect = false }; bool? ok = itemDlg.ShowDialog();
if u do _not_ set a filter on the dialog then, by default, on construction, the itemDlg.Filters property shld be set to "esri_browseDialogFilters_gp_all" which excludes the portal "Node" by default....
However, if u need to force the Portal node to not show (because it is showing for some reason) then u can add an explicit "Exclude" to a browse filter:
BrowseProjectFilter bdf = new BrowseProjectFilter(); bdf.Name = "All files (*.*)"; bdf.BrowsingFilesMode = true; bdf.FileExtension = "*.*"; bdf.Includes.Add(@"FolderConnection"); //Does not display Online places in the browse dialog bdf.Excludes.Add(@"esri_browsePlaces_Online"); bdf.BrowsingFilesMode = true; OpenItemDialog itemDlg = new OpenItemDialog { Title = "Open Files", InitialLocation = @"E:\Data\Test", MultiSelect = false, BrowseFilter = bdf }; bool? ok = itemDlg.ShowDialog();
As the default filters usually exclude the Portal node, if you need to _add_ the portal Node, then construct a browse filter that does _not_ exclude it like so:
BrowseProjectFilter bdf = new BrowseProjectFilter(); bdf.Name = "All files (*.*)"; bdf.BrowsingFilesMode = true; bdf.FileExtension = "*.*"; bdf.Includes.Add(@"FolderConnection"); bdf.BrowsingFilesMode = true; //Do not exclude online places //"Exclude" of Online places has been removed... OpenItemDialog itemDlg = new OpenItemDialog { Title = "Open Files", InitialLocation = @"E:\Data\Test", MultiSelect = false, BrowseFilter = bdf }; bool? ok = itemDlg.ShowDialog();
I was using a feature class filter. The exclude example helped me get it working, thanks.
