I am trying to fetch address using Geocode Suggestion API and Geocode result API.
When I normally load results from
locatorTask.geocode(query, geocodeParams)
then it returns the results but when I try
locatorTask.suggest(query)
and after click on one of the suggestion result
locatorTask.geocode(suggestion, geocodeParams)
then app get crashed every time with crash
FATAL EXCEPTION: OkHttp Dispatcher
java.lang.NoClassDefFoundError: Failed resolution of: Lokhttp3/internal/Util;
at okhttp3.JavaNetCookieJar.decodeHeaderAsJavaNetCookies(JavaNetCookieJar.kt:81)
at okhttp3.JavaNetCookieJar.loadForRequest(JavaNetCookieJar.kt:59)
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.kt:74)
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:109)
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.kt:64)
at com.arcgismaps.http.internal.ntlm.NtlmInterceptor.intercept(NtlmInterceptor.kt:53)
at okhttp3.internal.connection.RealCall.getResponseWithInterceptorChain$okhttp(RealCall.kt:205)
at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:533)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1137)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:637)
at java.lang.Thread.run(Thread.java:1012)
Caused by: java.lang.ClassNotFoundException: Didn't find class "okhttp3.internal.Util" on path: DexPathList
at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:259)
at java.lang.ClassLoader.loadClass(ClassLoader.java:379)
at java.lang.ClassLoader.loadClass(ClassLoader.java:312)
