Hello everyone.
I am trying to import a KMZ file into CityEngine but when I add it nothing happens. I went to check the Logs file and I get this error: java.io.IOException: KML Importer: no valid placemarks detected, file is probably too old (< KML v2.1) or corrupt
The same file I can open without problems in ArcGIS Pro (3.0.3). The KMZ file comes from Google Earth but I also tested converting a polygon to KMZ in ArcGIS Pro and even that file I can't open in CE.
Any suggestions on how to overcome it?
Thank you
