var visLayers = layer.visibleLayers; if (visLayers !== -1) { identifyParams.layerIds = layer.visibleLayers; }
function executeIdentifyTask(evt) { identifyParams.geometry = evt.mapPoint; identifyParams.mapExtent = map.extent; identifyParams.layerIds = lubbock.visibleLayers; var deferred = identifyTask.execute(identifyParams);
function mapReady(map) { dojo.connect(map, "onClick", executeIdentifyTask); //create identify tasks and setup parameters identifyTask = new esri.tasks.IdentifyTask("http://maps101.gis.halff.com/ladon/rest/services/Lubbock/LubbockCCTVAssets/MapServer/"); identifyParams = new esri.tasks.IdentifyParameters(); identifyParams.tolerance = 3; identifyParams.returnGeometry = true; identifyParams.layerIds = [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17]; identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL; identifyParams.width = map.width; identifyParams.height = map.height; } function executeIdentifyTask(evt) { identifyParams.geometry = evt.mapPoint; identifyParams.mapExtent = map.extent; var deferred = identifyTask.execute(identifyParams); deferred.addCallback(function (response) { // response is an array of identify result objects // Let's return an array of features. return dojo.map(response, function (result) { var feature = result.feature; feature.attributes.layerName = result.layerName; if (result.layerName === 'Survey Points') { console.log(feature.attributes.OBJECTID); var template = new esri.InfoTemplate("Survey Points", "<br/> Unique ID: ${UNIQUE_ID}<br/> X Coord: ${X_COORD}<br/> Y Coord: ${Y_COORD}<br/> Z Coord: ${Z_COORD}<br/> Type:${Type}<br/> Status: ${Status}<br/> Data Source: ${DATA_SOURCE}<br/> Shape: ${SHAPE}<br/> Survey Date: ${SURVEY_DATE}<br/>Alternate Name: ${ALT_NAME}"); feature.setInfoTemplate(template); } else if (result.layerName === 'CCTV Observations') { var template = new esri.InfoTemplate("CCTV Observations", "<br/> CCTV Route: ${CCTV_ROUTE}<br/> CCTV Distance: ${CCTV_DISTANCE}<br/> CCTV Code: ${CCTV_CODE}<br/> CCTV Value Percent: ${CCTV_VALUE_PERCENT}<br/> CCTV Clock From: ${CCTV_CLOCK_FROM}<br/> CCTV Clock To: ${CCTV_CLOCK_TO}<br/> CCTV Grade: ${CCTV_GRADE} <br/>CCTV Continuous: ${CCTV_CONTINUOUS}<br/> CCTV Observation Type:${CCTV_OBS_TYPE}<br/> CCTV Observation:${CCTV_OBSERVATION}<br/> CCTV Remark:${CCTV_REMARK} <br/>Shape:${SHAPE}<br/> CCTV Attachment:${CCTV_Attach}"); feature.setInfoTemplate(template); } else if (result.layerName === 'Manholes') { var template = new esri.InfoTemplate("Manholes", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Inlets') { var template = new esri.InfoTemplate("Inlets", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Infalls') { var template = new esri.InfoTemplate("Infalls", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Outfalls') { var template = new esri.InfoTemplate("Outfalls", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Channel Features') { var template = new esri.InfoTemplate("Channel Features", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Pipe Features') { var template = new esri.InfoTemplate("Pipe Features", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Playa Centroids') { var template = new esri.InfoTemplate("Playa Centroids", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Pipes') { var template = new esri.InfoTemplate("Pipes", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Flumes') { var template = new esri.InfoTemplate("Flumes", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Dams') { var template = new esri.InfoTemplate("Dams", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Channels') { var template = new esri.InfoTemplate("Channels", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'CCTV Routes') { var template = new esri.InfoTemplate("CCTV Routes", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Virtual Links') { var template = new esri.InfoTemplate("Virtual Links", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Stormwater Systems') { var template = new esri.InfoTemplate("Stormwater Systems", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Asset Footprints') { var template = new esri.InfoTemplate("Asset Footprints", "${*}") feature.setInfoTemplate(template); } else if (result.layerName === 'Playa Lakes') { var template = new esri.InfoTemplate("Playa Lakes", "${*}") feature.setInfoTemplate(template); } map.infoWindow.setFeatures([deferred]); map.infoWindow.show(evt.mapPoint); return feature; }); });
layerDynamic= new esri.layers.ArcGISDynamicMapServiceLayer(parameters.url, { id: 'Dynamic' }); map.addLayers([layerDynamic]); layerDynamic.setVisibleLayers(parameters.visibleLayers); map.on("layers-add-result", function (event) { try { var toc = new agsjs.dijit.TOC({ map: map, layerInfos: [{ layer: layerDynamic, title: "Legend", slider: true }] }, 'tocDiv'); toc.startup(); } catch (e) { console.log(e.message); } mapReady(map); }); function mapReady(map) { map.on("click", executeIdentifyTask); identifyTask = new esri.tasks.IdentifyTask(parameters.url); identifyParams = new esri.tasks.IdentifyParameters(); identifyParams.tolerance = 3; identifyParams.returnGeometry = true; //identifyParams.layerIds = [0, 117]; identifyParams.layerIds = layerDynamic.visibleLayers; identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE; identifyParams.width = map.width; identifyParams.height = map.height; map.infoWindow.resize(415, 200); map.infoWindow.setContent(tc.domNode); map.infoWindow.setTitle("Results"); } function executeIdentifyTask(evt) { map.graphics.clear(); identifyParams.geometry = evt.mapPoint; identifyParams.mapExtent = map.extent; identifyParams.layerIds = layerDynamic.visibleLayers;
var lubbock = new esri.layers.ArcGISDynamicMapServiceLayer("http://maps101.gis.halff.com/ladon/rest/services/Lubbock/LubbockCCTVAssets/MapServer", { id: 'lubbock', opacity: 0.8 }); dojo.connect(map, 'onLayersAddResult', function (results) { var toc = new agsjs.dijit.TOC({ map: map, layerInfos: [{ layer: lubbock, title: "Lubbock CCTV Assets" }, ] }, 'tocDiv'); toc.startup(); lubbock.setVisibleLayers([9]); }); map.addLayers([lubbock]);
function mapReady(map) { dojo.connect(map, "onClick", executeIdentifyTask); //create identify tasks and setup parameters identifyTask = new esri.tasks.IdentifyTask("http://maps101.gis.halff.com/ladon/rest/services/Lubbock/LubbockCCTVAssets/MapServer/"); identifyParams = new esri.tasks.IdentifyParameters(); identifyParams.tolerance = 3; identifyParams.returnGeometry = true; identifyParams.layerIds = [1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17] identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE; identifyParams.width = map.width; identifyParams.height = map.height; }
identifyParams.layerIds = SurveyPoints.visibleLayers;
