Hello
I have features that contain a hyperlink field that in the old versions of arcmap, one could use the hyperlink tool and the image/pdf would open
Now I am trying to use these same links in portal. I see where it lets one select a url path but it wont let me add a path pointed on the server?
Also, it appears that if I did have the option to point to file location(which some of the apps allow) one can only do this manually, where each would have to be clicked on and pointed to the image file.
Is there a way to use a field in a feature that works as the old hyperlink tool did or does one have to manually click and navigate to each to get the hyperlinks to work?
