I am trying to add a WebMap object to my dashboard that I am creating:
dashboard = Dashboard()
dashboard.title = "My Network"
indicator04 = Indicator(item = feature_layer_item, name = "KPI 1", title = "KPI 1")
indicator04.data.value_type = "statistic"
indicator04.data.value_field = "kpi1"
indicator04.height=0.1
my_webmap = WebMap()
my_webmap.add_layer(feature_layer_item, options={'title':'Links'})
dashboard.layout = add_column([indicator04, my_webmap])
The error that I get is this:
Warning Traceback (most recent call last)
In [36]:
Line 1: dashboard.layout = add_row([add_column([indicator04, my_webmap])])
File C:\Users\MyUser1\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\apps\dashboard\_utils\_basewidget.py, in add_column:
Line 401: elements = _auto_calculate_width(elements)
File C:\Users\MyUser1\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\apps\dashboard\_utils\_basewidget.py, in _auto_calculate_width:
Line 295: element_width = getattr(el, "width", 1)
File C:\Users\MyUser1\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\mapping\_types.py, in width:
Line 2424: raise Warning(
Warning: This property is no longer supported and does not operate on the resource.
In addition, when I access my dashboard, I am getting a blank screen.
I tried around a couple of things and the following code blocks work:
# Generates a dashboard with only the indicator
dashboard.layout = add_column([indicator04])
# Yields <class 'arcgis.features.layer.FeatureLayer'>
type(feature_layer)
# Yields a WebMap with my desired layer
my_webmap
Is there another way for me to add the WebMap to the dashboard? There does not seem to be many directions on how to do this when creating a new dashboard at the same time.
Note: This error happens for add_column([indicator04, my_webmap]) and add_row([indicator04, my_webmap]) as well.
