I am using the zoom and flash trigger in EXB on my map. It zooms, but nothing is flashing. Even better I would just like it outlined so it sticks out from the parcels surrounding it.
Enterprise Environment - 10.9.1
I tried it on AGOL and the zoom and flash work fine:
As for the flash styles, currently, it is not editable. However, feel free to bring it up in the Ideas channel and we will evaluate based on the feedback. Thanks for bringing this up.
I am using Portal. It has worked before, just doesn't seem to work right now. I am doing this through a query result.
Tried using query with the record selection change > Flash, with the correct connection of trigger and action fields, still works fine. @Laura It might be better to reach out to Esri Support so that the analysts could help further identify the version and also reproducible steps and environment for us to take a look. Thanks.
Same problem with me. I'm using Portal (Enterprise 10.9.1), not AGO, and query results selection doesn't flash. It only Zooms. I've tried adding many back-to-back Flash actions. It never flashes the point. Frustrating. I just need to show the users the selected feature somehow. Does this work for anyone?
@TonghuiMing @Andy_Morgan I have opened a case with support. We have tried multiple actions and have not found a viable solution. It appears that it works properly in 11.0, however I am not prepared to upgrade my environment at this moment. So far, there is no bug logged.
