I often have the need to add additional data into the feature service that was collected outside of the app. I get this error when I copy data into a feature service that has a Survey123 form. When I paste or append data to the feature service using ArcGIS Pro, I get this error:
"General Function Failure: Error Code 1000. The Insert Statement Conflicted with the foreign key constraint."
Is there a way I can change the constraint? Is there another workflow I should be using?
