How can one programmatically sort a table on a given field? This functionality is achieved in Pro by the user right clicking on a given field and electing to sort descending or ascending on that field. Is this attainable using the pro sdk?
@UmaHarano @CharlesMacleod @Wolf
Starting with Release 3.1, you can use the TableView class as described here: ProConcepts Map Exploration · Esri/arcgis-pro-sdk Wiki (github.com)
and specifically the SortAscending Method: SortAscending Method (TableView)—ArcGIS Pro
The code would look like this:
var tv = TableView.Active; if (tv == null) return; // sort the active field descending if (tv.CanSortDescending) tv.SortDescending(); // sort the active field ascending if (tv.CanSortAscending) tv.SortAscending(); // peform a custom sort programmatically if (tv.CanCustomSort) { // sort fields var dict = new Dictionary<string, FieldSortInfo>(); dict.Add("STATE_NAME", FieldSortInfo.Asc); dict.Add("CITY_NAME", FieldSortInfo.Desc); await tv.SortAsync(dict); } // perform a custom sort via the UI if (tv.CanCustomSort) tv.CustomSort();
You can also search for the videos from Dev Summit 2023 specifically the session:
"Intermediate Data Visualization Using Table Controls"
You can find the session resources here: Tech Sessions · Esri/arcgis-pro-sdk Wiki (github.com)
