var spatRef:SpatialReference = new SpatialReference(102100); var pl:Polyline = new Polyline(null, spatRef); var path:Array = []; path.push(new MapPoint(15558700, 1770100, spatRef)); path.push(new MapPoint(12959100, 3238400, spatRef)); path.push(new MapPoint(11901900, 3238400, spatRef)); path.push(new MapPoint(1447100, 4244300, spatRef)); path.push(new MapPoint(-13627000, 2012200, spatRef)); path.push(new MapPoint(-13330400, 1623400, spatRef)); path.push(new MapPoint(-8733100, -24400, spatRef)); path.push(new MapPoint(-7449500, 1175400, spatRef)); path.push(new MapPoint(-6681300, -4460100, spatRef)); pl.paths = [path]; var graphic:Graphic = new Graphic(pl, null, null);
Zahid, So you are saying that this does not work? var spatRef:SpatialReference = new SpatialReference(102100); var pl:Polyline = new Polyline(null, spatRef); var path:Array = []; path.push(new MapPoint(15558700, 1770100, spatRef)); path.push(new MapPoint(12959100, 3238400, spatRef)); path.push(new MapPoint(11901900, 3238400, spatRef)); path.push(new MapPoint(1447100, 4244300, spatRef)); path.push(new MapPoint(-13627000, 2012200, spatRef)); path.push(new MapPoint(-13330400, 1623400, spatRef)); path.push(new MapPoint(-8733100, -24400, spatRef)); path.push(new MapPoint(-7449500, 1175400, spatRef)); path.push(new MapPoint(-6681300, -4460100, spatRef)); pl.paths = [path]; var graphic:Graphic = new Graphic(pl, null, null);
Zahid, Try this:var spatRef:SpatialReference = new SpatialReference(102100); var pl:Polyline = new Polyline(null, spatRef); var path:Array = []; path.push(new MapPoint(15558700, 1770100, spatRef)); path.push(new MapPoint(12959100, 3238400, spatRef)); path.push(new MapPoint(11901900, 3238400, spatRef)); path.push(new MapPoint(1447100, 4244300, spatRef)); path.push(new MapPoint(-13627000, 2012200, spatRef)); path.push(new MapPoint(-13330400, 1623400, spatRef)); path.push(new MapPoint(-8733100, -24400, spatRef)); path.push(new MapPoint(-7449500, 1175400, spatRef)); path.push(new MapPoint(-6681300, -4460100, spatRef)); pl.paths = [path];Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).Follow the steps as shown in the below graphic:
