I am trying to add below html marker.
<span>
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<svg width="30px" height="44px" viewBox="0 0 30 40" version="1.1" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink">
<defs></defs>
<g stroke="none" stroke-width="1" fill="none" fill-rule="evenodd">
<g id="map-marker" fill="red">
<ellipse id="Oval-1" fill-opacity="0.167006341" fill="#000000" cx="15" cy="39" rx="10" ry="5"></ellipse>
<path d="M14.9603111,0.0389586363 C6.69825573,0.0389586363 0,6.73721437 0,14.9992698 C0,23.2608382 12.4667636,39.932797 14.9603111,39.932797 C17.4533717,39.932797 29.9201353,23.2608382 29.9201353,14.9992698 C29.9201353,6.73721437 23.2218795,0.0389586363 14.9603111,0.0389586363 L14.9603111,0.0389586363 Z" id="Fill-1"></path>
</g>
</g>
</svg>
</span>
is there any way we can achieve that ? . I am using "@arcgis/core": "^4.26.5" library and Nextjs.
Right now , I can achieve the rendering of the svg using SimpleMarkerSymbol and path property which results in below image
but I can add the path of outer bubble and I cannot achieve the above use case. Is there any way to add html code ?
