I have a bunch of property boundaries that were all made by a bunch of different companies so they are all just slightly misaligned to each other. I wanted to correct this so all the lines neatly match up as parcels should be. So I had been tracing them but its taking forever to do all of them so thought I'd try to use the snap geoprocesing tool. here is my process:
1. Use the densify tool to add vertices around the polygon of the feature I want to alter so there are more snap locations
2. Use the Snap tool against the selected polygon I want it snapped to, type edge, 50 ft distance
And just nothing happens... No points are moved, I've tried altering the snap environment but nothing moves the point. What am I doing wrong? The documentation literally says to do exactly what I want but when I try it just doesn't do anything at all.
