Hello. I am a Survey123 user and I would like to switch to Field Maps. Unfortunately, at least this is my impression, the documentation currently available is unclear or partial. For me, who is not a programmer, it is not easy to understand what needs to be done and how to do it. For example, in the article Common calculated expressions for ArcGIS Field Maps - Point 5, I read that it is possible to store the coordinate values of a point. So far so good. I followed the instructions and now I have two fields with the coordinates of our AGOL feature layer. Only that the coordinates are logically those of the map that uses the WGS 1984 Web Mercator (Auxiliary Sphere) system, while I need them in the WGS 1984 UTM Zone 33 system. In the example that calculates latitude and longitude coordinates, there is a script that I think can be modified to calculate coordinates in the system I need. But first of all, where does the script go? How do you tell it to write values in two specific fields? How should the script be modified to use my reference system? Thanks for your help.
