Hello evryone,
i have created a spatial views in Enterprise geodatabade and registred the view succsesufly.
but when i open the view in the map the polygon doesn't show, the table is not empty and when i select a feature in the table i can zoom to it but it doesn't show on the map
the sql code is:
SELECT pat_entite_z1.SHAPE, pat_patrimoine.code_pat, pat_patrimoine.nature_juridique, pat_patrimoine.ligne, pat_patrimoine.conservation, pat_patrimoine.superficie_depot, pat_patrimoine.etat_immatriculation, 'R' || pat_patrimoine.numero_requisition || '/' || pat_patrimoine.index_requisition AS req, 'T' || pat_patrimoine.num_tf || '/' || pat_patrimoine.index_tf AS tf, pat_patrimoine.statut_pat, pat_patrimoine.superficie_defintive, pat_patrimoine.sortie, pat_patrimoine.nature_sortie, pat_patrimoine.obs, pat_patrimoine.ged, pat_patrimoine.depose_par, pat_patrimoine.immatricule_par, pat_patrimoine.verification
FROM pat_patrimoine INNER JOIN pat_entite_z1 ON pat_patrimoine.code_pat = pat_entite_z1.code_pat;
i have also published the view in portal but i have the same problem.
can you help me
thanks
