Hello, I'm trying to architect a microfrontend project under ArcGIS JSAPI.
However, I've encountered a critical issue where different remote applications using the ArcGIS JS API result in an error,such as „Logger.js:5 [esri.core.Accessor] Accessor#set Assigning an instance of 'esri.geometry.SpatialReference' which is not a subclass of 'esri.geometry.SpatialReference“
I've read similar issues such as "https://community.esri.com/t5/arcgis-javascript-maps-sdk-questions/problem-using-es-modules-in-webpack-module/m-p/1129100", but there doesn't seem to be an out-of-the-box solution provided. I was wondering if there were any progress or shared knowledge from the internal team regarding microfrontends?
I can probably guess the reason for this error. I instantiated the Access class of the API in different micro-frontends that are not aware of each other, which has to do with the prototype chain. However, I'm not sure how to handle this issue.
