Hello everyone,
Anyone can recommend samples of Python source code updating hosted feature layers?
Jose
If you're looking to append then give this a try...
import arcgis
# Set the URL of your ArcGIS Online organizationportal_url = "https://www.arcgis.com/"
# Set the credentials for your ArcGIS Online accountusername = "<username>"password = "<password>"
# Set the ID of the feature service you want to updateservice_id = "<service_id>"
# Set the name of the feature class in your geodatabase that you want to update the service withfc_name = "<feature_class_name>"
# Connect to your ArcGIS Online organizationgis = arcgis.gis.GIS(portal_url, username, password)
# Get the feature servicefeature_service = arcgis.features.FeatureLayerCollection.fromitem(gis.content.get(service_id))
# Get the feature layer from the feature servicefeature_layer = feature_service.layers[0]
# Get the feature class from the geodatabasefeature_class = arcgis.features.FeatureSet.from_featureclass(fc_name)
# Update the feature service with the feature setfeature_layer.edit_features(updates=feature_class)
# Disconnect from the ArcGIS Online organizationgis = None
Thanks @avonmoos
In my case I am getting a feature class with new records that have to be append to the hosted feature class.
Does this line append the hosted feature with records?
# Use the feature set to update the feature layer
layer.edit_features(updates=feature_set)
import arcgisfrom arcgis.gis import GIS
# Connect to your ArcGIS Online organizationgis = GIS("https://www.arcgis.com", "username", "password")
# Get the feature layer you want to updatelayer = gis.content.get("feature_layer_item_id").layers[0]
# Create a feature set object containing the features you want to updatefeature_set = arcgis.features.FeatureSet.from_csv("path_to_csv_file")
# Use the feature set to update the feature layerlayer.edit_features(updates=feature_set)
print("Feature layer updated successfully!")
Thank you Jacob!
There's plenty of documentation, like here: https://developers.arcgis.com/python/guide/appending-features/
