Hi everyone,
I am trying to create a Data Expression within my dashboard to access some related records. I've set up a filter to access the data but am getting an error when trying to access the data from the Filter.
"Test execution error: Unknown Error. Verify test data."
I've added a few console outputs to test my results. I am able to get the output for the first console statement but then run into the error.
I've added the relevant portion of the script below.
var portalServ = Portal("https://www.arcgis.com/");
var pointFS = FeatureSetByPortalItem(
portalServ,
"featID",
0,
False
var tablefs = FeatureSetByPortalItem(
portalServ,
"featID",
1,
False
var features = [];
var feat;
var calls_sub_found_var;
for (var t in tablefs){
var TableID = t["op_record_id"]
console(TableID);
for (var p in Filter(pointFS,"op_record_id = "+Text(TableID))){
console(p["op_record_id"]);
Additionally, if I use the console to output the Filter object itself, I am able to return that. It is only when I try and start accessing the objects from the filter when I run into the error.
Would the amount of data be a factor in the filter failing? I'm working with ~120k point features and ~20k related records in total.
